How fast will she go????  (My buddy's boat) >
Old 04-02-2003 | 06:02 PM
MIKEHTMSR24's Avatar
Post How fast will she go???? (My buddy's boat)
Boat 2000 36 Outlaw
Had:
Stock 502's EFIs with Stainless Marine Headers
1.5 Bravo ones with labbed by Merc Bravo 1 24 pitch
Speed- 67 to 69
Now:
Top Mount Whipples with 6 lbs.
502s had new hyd. roller cams (builder will not give out specs).
Merlin steel heads.
Imco SC Extreme drives 1.5
What would be the new hp and the new speed. I know their are some holes not filled to determine the speed. But give it a stab!
Props to be determined. Probably 30 to 32.
Attached Thumbnails How fast will she go????  (My buddy's boat)-36-keith-crop.jpg
MIKEHTMSR24 is offline
Old 04-02-2003 | 06:09 PM
CESSNA
Talking
Sounds like he did it right ,just takes bucks !
Thats a heavy boat isn't it ??
Old 04-02-2003 | 06:15 PM
GLH's Avatar
GLH
Figure it out!
http://www.go-fast.com/boat_speed_predictions.htm
Don't forget the slip if you missing parameters.
http://www.go-fast.com/prop_slip.htm
http://www.go-fast.com/Prop_Slip_Calculator.htm
GLH is offline
Old 04-02-2003 | 06:25 PM
GLH's Avatar
GLH
502 EFI +415
Whipple 6# +250/220@prop
Roller Cam/Heads +25/+20@prop
Everything else (headers, drive) help the setup last a bit!
Total 645@prop x 2= 1290hp
Baja 36 Outlaw Dry 8300# wet,people&gear 9000+#
No step in the hull.
My amaterish guess 85 MPH
GLH is offline
Old 04-02-2003 | 06:27 PM
Default been there done all of that
Originally posted by GLH
Figure it out!
I want to know what your guess would be. One motor is in and the second motor is waiting on the dyno. We will soon know the speed but until then get your calulators out and let's see want you can come up with. The winner to the closest tenth of an mph wins the boat .
NOT
Old 04-02-2003 | 06:31 PM
Default I'm impressed with your homework but
502 EFI +415
you need to do more research on what a top mount will put on a stock 502 then add more hp due to the cam and heads.
Old 04-02-2003 | 06:32 PM
Allan4
I think 85ish is a pretty good guess.
I would say more along the lines of 83-85 gps.......
Old 04-02-2003 | 06:34 PM
Allen4 =84.5, GLH 85, Shane 89, Cord 82.5, Tim G 73, Fever Mike 78.5, jt29olhp500's 85.5,
Old 04-03-2003 | 06:47 AM
GLH's Avatar
GLH
Default Re: I'm impressed with your homework but
I told you I'm an amateur when it comes to engines most of those words are chinese to me!!!I don't know sh!t just using what I got. Let us know how fast!
GLH is offline
Old 04-03-2003 | 07:15 AM
208 MPH! Watch out Callan! I would say 89. Good luck.
Shane is offline
