Fiberglass cutting >
Fiberglass cutting
Fiberglass cutting
Old 04-08-2003 | 08:03 AM
Dave M's Avatar
Veteran: Navy
Default Fiberglass cutting
I have to cut out a 12" x 12" section of a bulkhead to install a foot rest. The bulkhead is fiberglass with balsa core. Should I seal the balsa core with some type of resin before installing the foot rest. It is in a place where it is not exposed to a lot of water. If so, what type of resin should I use?
Dave M.
Dave M is offline
Old 04-08-2003 | 08:21 AM
Yes, seal it. Use Epoxy, it sticks to everything.
Gary
Gary Anderson is offline
Old 04-08-2003 | 08:23 AM
GregP's Avatar
Buy some Git Rot penetrating epoxy (at most boat stores), it will soak nicely into the balsa grain and seal it.
-Greg
GregP is offline
Old 04-08-2003 | 08:19 PM
Ted G's Avatar
West System products also work well. You have to seal it, regardless of how much water might get up there.
www.cbpba.com
Ted G is offline
Old 04-08-2003 | 08:48 PM
Dave M's Avatar
Veteran: Navy
Thanks for the info guys. I am having nightmares about cutting this hole. I'm measuring 1000 times and hopefully only cutting once!
Dave M is offline
Old 04-08-2003 | 09:39 PM
Audiofn's Avatar
Charter Member #232
Just using the epoxy is probaby ok but if you REALLY want to do it correctly you should put Glass over it. Resin will not keep it from cracking and once you get a crack you will have a place for water to get in.
Jon
Put your best foot forward!
Audiofn is offline
Wahoo ATV
OPA/The Jersey Boyz
33
05-21-2008 04:35 PM
nocigarette
19
09-12-2006 09:05 PM
jafo272
08-19-2003 10:32 PM
rtn137
21
03-16-2003 07:13 PM
NotTOOBAD
Baja
4
02-16-2003 03:42 PM
