SSM III-IIIA >
SSM III-IIIA
SSM III-IIIA
Old 04-10-2003 | 07:43 AM
later's Avatar
Default SSM III-IIIA
how can you tell the difference from the early III and the later IIIa's
thanks
later
later is offline
Old 04-10-2003 | 08:44 AM
IIIAs have the larger 26 spline prop shaft. Uses the same props as SSM V and VI. IIIs have the smaller 19 spline 1 3/8" shaft.
There are also some differences in the gimbals in the later IIIAs to make them stronger.
Gary
Gary Anderson is offline
Old 04-10-2003 | 10:44 AM
later's Avatar
what year did the IIIa's start being produced?
later
later is offline
Old 04-10-2003 | 11:39 AM
Mbam's Avatar
Offshoreonly Advertiser
You can't tell by just the prop shaft, as it is possible to put the shaft from a big shaft #4 in a 3.
Take a look at the tilt pin hole, a 3 is 3/4, a 3A is 1". Of course it is possible to drill that out too.
Mbam is offline
Old 04-10-2003 | 12:15 PM
I guess I'll be more careful the next time I buy a IIIA from BAM
Old 04-12-2003 | 10:01 AM
Ike's Avatar
Ike
Charter Member#93
Marc, Will a 3a or 4 lower bolt right up to a #3?If not what do you need to do to convert them? Thank's, Ike.
Ike is offline
Old 04-12-2003 | 10:09 AM
Ike's Avatar
Ike
Charter Member#93
Marc, also what drive oil do you recommend for my #3's? Ike.
Ike is offline
Old 04-13-2003 | 07:22 AM
Mbam's Avatar
Ike, no way to convert. A 4 upper is a different housing. A 3 and 3A have different vertical shafts in the lower.
We us the good old Merc HP gear lube.
Mbam is offline
Old 04-18-2003 | 01:48 AM
What are the differences between a 3a and a 5 other than length?
I've got 5's on a boatwith stellings boxes we're riggin and we're just now dialin in the props. Maybe a cupped prop will help us get on plane faster.
Its a 38 that weighs 7800lbs. The drives are right below the transom, We're gonna try some cupped props next week to get that thing to plane off.
Surgin' General is offline
sdpm
Swap Shop
5
10-22-2008 11:58 AM
Michael1
Drives and Lower Units
3
07-06-2007 09:16 PM
Luuk
0
05-24-2007 04:09 PM
GO4BROKE
3
06-15-2005 08:27 PM
timucin
4
11-03-2002 07:29 PM
