Crossovers
Old 04-16-2003 | 09:35 PM
robert johnson's Avatar
Default Crossovers
I've been reading your stuff for months,it's all Great,first time I posted, here goes....I know they say that a Alpha drive water pump will not support a small blocks cooling at idle. Is this because of the restriction from the thermostat? and if it is is it possible to use the manifolds to pre-heat the water first then go through the engine thus eliminating the thermostat? The reason I ask is I have my dad's old crackerbox, 283 small block chevy and that is how it is plumbed. I noticed the other day that the neo-vane pump on it dosn't look any bigger than the one in the drive? I've been thinking about this for days, thanks in advance!
robert johnson is offline
Old 04-16-2003 | 11:12 PM
paradigm shift's Avatar
Welcome to the board first. I have seen BBC ran off alpha water pumps before so I do not see a problem with a SBC. You could use the manifolds to preheat your water but most run a restrictive orifice also to keep water pressure at an acceptable level. Crackerbox that has to be a blast to drive!
paradigm shift is offline
Old 04-17-2003 | 08:14 AM
Plenty of water for a small block. Marginal for a big block.
BROWNIE is offline
Old 04-17-2003 | 05:15 PM
Thanx guys! I am going to try it. The crackerbox is a blast, my uncle built it in 53 and its been in the family ever since. Also I heard there is a impeller for the outdrives that is better than the rest?
jryan26
Wanted
1
06-28-2008 10:23 AM
shaun harrington
Wanted
10
06-19-2008 10:41 PM
wet_rat
Wanted
7
03-05-2008 11:01 AM
sre
4
05-03-2007 12:43 PM
Mark
11-05-2002 12:05 PM
