hp500 valve springs >
hp500 valve springs
hp500 valve springs
Old 04-18-2003 | 06:01 AM
Default hp500 valve springs
i am at 165 hours use boat moderately. should i change springs now.
what is the best spring to upgrade to and the best place to get them. prefabley in the north east.
also the best place to get a 26 4 blade bravo1 prop labbed, need 400 more rpm,s
thanks for any help 25 thunder
rssteiny is offline
Old 04-18-2003 | 06:18 AM
I have heard good things about the comp cams 929-16.
BadDog is offline
Old 04-18-2003 | 06:45 AM
mtm's Avatar
mtm
Default springs
i would use the new crane #99896 these are the new springs that merc uses on all the new hp stuff
mtm is online now
Old 04-18-2003 | 07:04 AM
Scott's Avatar
Charter Member #30
Default Re: springs
I found the pressures still high with the Crane springs. Isky would now be my first choice (pricey) and the Comps would be a good second choice.
If your motors are EFI I would consider a change or at least a valve trane inspection. They may still be ok for a while. If your motors are the carb version you are running on borrowed time! The springs that are on there are bad! If they are carb motors I would also check out the lifters and make sure crimp on the roller keeper is ok.
I know it may sound like a pain but this will save you money and downtime.
I have Steps & Bubbles!
Scott is offline
Old 04-18-2003 | 08:27 AM
Dave1972's Avatar
Darin at Houston Propellor would be the guy for the extra RPMs for your prop!1
Dave1972 is offline
Old 04-18-2003 | 12:28 PM
bobby daniels
SCOTT AND DAVE are telling you right !!!!
The 929 springs work well their coated ones are even better but the Isky valve train parts are second to none ,,pm me I can get a great price on the number you want
Old 04-18-2003 | 12:47 PM
StrikinLightnin's Avatar
Aren't EFI engines already using CompCAMS springs?
If so how many hours are they good for?
StrikinLightnin is offline
Old 04-18-2003 | 02:55 PM
bobby daniels
some are it depends on year the older ones had Crane that at around 100 hrs got very weak ( DEPENDING on driveing style) !
Coated springs are worth the money and last ,If you can use ISKY talk with Ron Iskenderian (323-770-0930 ) or I'll help with a price ,good luck !!!!!!!!!!!!
Old 04-19-2003 | 02:00 PM
Just got 2 1996 HP 500's carb motors 250hrs 2 broken valve springs.
Dixie Doug is offline
Old 04-19-2003 | 03:15 PM
bobby daniels
Thats the norm for that year ! glad you caught it are the lifters O,K, ????
