No Spark
Old 04-19-2003 | 12:00 PM
rockdaddy
Default No Spark
Help Anyone?
Todays project was to change the oil & filter in the boat
first start of the season, engine 1 started and running fine changed oil no problem
Started 2nd engine ran 5 min and died, checked and found no spark to plugs or cap, checked circuit breakers ect OK. +side of coil has power.
Any suggestions?
oh it a 1989 Formula F-311 with 7.4 420's
Old 04-19-2003 | 01:57 PM
Sounds like a bad coil. Pull the one off the other engine and try it.
The beauty of twins.
Griff is offline
Old 04-19-2003 | 05:57 PM
rockdaddy
I have tried swapping the coil & what l would call an ignition module with no help
the only difference i found with my test light was no power on the white/red wire going into the distributor on the no start motor
Any ideas?
Old 04-19-2003 | 06:17 PM
cig1988's Avatar
This sound stupid but it's happened to me. Did you check the dead man switch?
cig1988 is offline
Old 04-20-2003 | 10:47 AM
rockdaddy
Dead mans switch checked out OK
I'm thinking maybe Pickup module in distributor?
Old 04-21-2003 | 06:52 AM
This just happened to me to, it was the ingnition ground wire from the distributor and the module. cleaned it and reinstalled and runs fine now...
HOTROD2 is offline
Old 04-22-2003 | 07:04 AM
rockdaddy
Good News,
Replaced the Ignition sensor last night and she's running like a charm again
Now I just have to wait for the lake to thaw
Thanks for the Help
SKRAMER
2
05-10-2008 09:12 AM
custom29scarab
6
05-26-2006 08:04 PM
TwoKs
2
08-21-2003 05:27 PM
F223LS
4
05-27-2002 07:09 AM
F223LS
0
05-26-2002 07:30 AM
