Awe........damnnnnnnnnn
From: On the back of a chicks M3..If you're gonna ride my ass at least pull my hair!!
Well took the boat out yesterday and guess what???????
It's leaking water in the bilge.........DAMN DAMN DAMN
Well not really that mad....actually not at all....the mechanics problem not mine......anyways the motor has to come out again!!!!
Should be simple......The Y-pipe is leaking.Not bad but leaking nonetheless.I can see the water trail on the tops side in the valleys of the bolt holes.No way in hell you're gonna get to those bolts with the motor in.
I now someone makes those "block-off" plates for the y-pipe.Where would I find one?????
Oh and jumped a 43 Sea-ray wake .......not only scared tyhe SHIIIIIT out of Tammy..her first timeout.....but broke the support for the windshield!!!!.Little plastic and aluminum rod..This was actually funny
Official OSO boat whore
Merc makes the plate. If you get in there with a cut off wheel you can cut the Y pipe and install the block off plate without pulling the engine.
How much are these plates???????
I don't see gettin anywhere close to this y-pipe......hell you can't even touch the bolts that hold it......not to mention the two bottom ones.......
Reckless32
03-21-2003 03:03 PM
Risk Taker
03-19-2003 09:21 PM
