Alhpa hinge pin torque? >
Old 05-01-2003 | 07:03 AM
patrick22309
Default Alhpa hinge pin torque?
I have seen numbers ranging from 40ft lbs to 90-100ft lbs. Thinking of going a happy medium with the red stuff. Anyone know the correct #?
Old 05-01-2003 | 07:09 AM
If you are going to do the maintenance I would not lock tite them. Just torque em down good and check them after some runtime.
BadDog is offline
Old 05-01-2003 | 07:15 AM
patrick22309
Makes sense, easy enough to adjust trim limit and sender after checking regularly.
Old 05-01-2003 | 09:55 PM
Rambunctious's Avatar
don't know about alpha, but the spec for bravo is 50 ft-lbs
i used 1 drop of locktight just to not worry about it backing out.
Rambunctious is offline
Old 05-02-2003 | 05:20 AM
Iggy's Avatar
Alpha hinge pins are torqued to 95 ft-lb. Manual also says to use Loctite on the threads.
Iggy is offline
Old 05-02-2003 | 06:57 AM
Sift through the various years of manuals and you will find several different torque values. When using Loc Tite and the higher values there was trouble with seizing and stripping threads. Go about 75 and grease them. Check after a period of time.
BadDog is offline
Old 05-02-2003 | 06:59 AM
patrick22309
I did that the first time like my manual states and though it extreme for going into an aluminum bell housing, shortening the life of the threads. LowerUnits.com states 40ft lbs. I went to 50ft lbs last night and will keep an eye on them.
epeek
11
04-02-2023 10:20 AM
epeek
19
01-08-2008 03:01 AM
cig1988
3
01-02-2003 01:44 PM
mr_velocity
09-06-2002 09:02 AM
blue thunder
17
01-09-2002 07:36 PM
