prop help
Old 05-04-2003 | 07:14 PM
racinbird
Default prop help
I could use some advice here. I have a 97' baja boss with a 500 horse 502. Im running a 4-blade 24p prop. I hit around 70 mph (gps) at 5100 rpm, Im sure this motor can pull more rpm and I really belive this boat should have a higher top speed with my setup. Its got rebuilt merlin heads, headers, 750 holley double pumper carb, and full MSD ignition with rebuilt distributor and new plugs. Any ideas on a prop choice for more top speed? The low-mid range is awesome so I doubt losing some low end would hurt much, Thanks
Old 05-04-2003 | 07:24 PM
jay21hat
hmm, talk to mark or milt at work - and call the prop shop tomarrow during work hours. I think you should go to a 26 pitch four blade. the only reason I am responding is because OSO will not allow me to view forums anymore unless I register - chat with you later
Old 05-04-2003 | 09:36 PM
Get a hold of Darin, at [email protected] He can help you out
88 MACH 1 is offline
Old 05-04-2003 | 09:49 PM
What size Baja??? If its a 24 Outlaw or a 272, you're in the ball park with that speed and hp. You may be able to pick up a few mph with some prop work. A 25 Mirage plus will give you some more on top but kill the holeshot and midrange.
Griff is offline
Old 05-04-2003 | 10:25 PM
dougB
labbed 25 mirage prop will do the trick/Darin @ Houston Prop or work the bravo one have it labbed to pickup 200 rpm and that might boost the speed up some.
Old 05-05-2003 | 06:40 AM
If you want to go the 25 MP route PM me. I have a as new box stock 25 Mirage Plus solid hub I no longer need.
BadDog is offline
Old 05-05-2003 | 06:52 AM
racinbird
sorry guys, its a 232 baja boss
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
