Msd Distributor Replacement >
Old 05-06-2003 | 05:02 AM
Default Msd Distributor Replacement
I WANT TO REPLACE MY MSD DISTRIBUTOR. IT IS CONSTANTLY RUSTING UP, SO BAD INFACT THAT THERE IS RUST ON THE INSIDE OF THE CAP. I HAVE TWO MSD BOXES (ONE IN USE AND A BRAND NEW BACKUP)AND THE SOFT TOUCH REV LIMITER SO I DON'T WANT TO REPLACE THE WHOLE SYSTEM. IS THERE ANOUTHER DISTRIBUTER THAT I CAN USE WITH THIS SYSTEM. IF I PLUG THE VENT HOLES WOULD THIS HELP IT TO RUST LESS OR ARE THE VENTS NECCESSARY. I ALSO USE A LOCKED OUT TIMING SET AT 35*.
THANKS FOR ANY INPUT
MIKE H is offline
Old 05-06-2003 | 08:11 AM
mcollinstn's Avatar
Remove the trigger and paint the insides. Just make sure you keep a clean ground pad for the trigger. Reinstall the trigger, and brush liquid rubber on any exposed metal. Vents are necessary, but you CAN hose them to a polyester filter.
mcollinstn is offline
Old 05-06-2003 | 09:56 AM
Is there any special type of paint that needs to be used on the trigger or will Tremclad rust paint work and when venting through a polyester filter where is the best location to vent it to?
Thanks for the reply
MIKE H is offline
Old 05-06-2003 | 11:55 AM
bobby daniels
Most dist. will work just fine ,but paint is the answer as the msd is a great dist ,most of the time you can get away with out the hole ,,,if it starts mis firing then put the hole back
Old 05-07-2003 | 12:16 AM
rbtnt's Avatar
MSD will do a complete rebuild for $75. That includes all new parts on the top end and new gear and bushings on the bottom end. I don't think it includes a cap or rotor. I sent an old one last spring with an old cap and rotor and they sent it back with new cap and rotor. Last fall I sent one in without cap and rotor and it came back without cap and rotor.
rbtnt is offline
Old 05-07-2003 | 05:21 AM
RLW
Had my MSD distributor rebuilt this winter. It came back like brand new with new cap and rotor. Considering the price for a new cap and rotor, it is a great deal. Now I can see how long it takes to rust up.
RLW is offline
Old 05-07-2003 | 06:03 AM
birdog's Avatar
Remove cap..........spray inside down with WD-40...Once or
twice per season...fresh water......more often salt
birdog is offline
Old 05-07-2003 | 07:57 AM
mcollinstn's Avatar
Any decent primer/paint combo. Krylon/Rustoleum/PlastiKote, etc..
Old 05-07-2003 | 09:04 AM
Thanks for all responses, gives me lots to work with.
MIKE H is offline
Old 05-11-2003 | 07:18 PM
Smile
I had the same corrosion problem in my first MSD distributor. I replaced the distributor (didn't know about the good deal on MSD refurbishing service).
Tyler Crockett recommended spraying CRC brand Industrial SP-400 Corrosion Inihibitor (part no. 03282) all over the inside of the new distributor, including the inside of the cap and rotor. It leaves a translucent coating that dries and isn't oily. I had to get my local hardware store to special order this spray because it is an industrial product.
The distributor is perfect after three years and counting. Each year when I replace the distributor cap and rotor I spray these new parts. Afterward, the first couple times I run the boat I get a kind of sweet smell, probably from the arcing inside the cap burning off some of the coating.
Escape Velocity is offline
Ran-Dom 32
Wanted
0
02-21-2008 02:51 PM
Pure Energy
15
08-20-2006 09:26 AM
H2oRigger
23
07-22-2006 08:31 AM
Donman
13
07-12-2006 06:56 PM
Vinny P
23
03-20-2005 06:43 PM
