dumb q about throttle mounted trim switches? >
Old 05-15-2003 | 08:07 AM
Default dumb q about throttle mounted trim switches?
Can you buy the add on trim switches that clamp on to the throttle levers with 2 switches in them
The only ones that I have ever seen have just had one switch.
If so where is a good place to buy them and what ahould I expect to pay for one?
THRILLSEEKER is offline
Old 05-15-2003 | 08:23 AM
Raypanic's Avatar
CLAMP-ON TRIM SWITCH SINGLE
Operate multiple drives or tabs
Designed for Gaffrig® controls
Can be used with Zero-effort Mercury or Morse controls if slightly modified
High quality and waterproof
Left or right handed
Trim switch single right black TRS $96
Trim switch single right white TRSW $99
Trim switch single left black TRSL $96
Trim switch single left white TRSLW $99
Trim switch dual right white** TRSDW $134
Trim switch dual left white** TRSDLW $138
*Diode kit included
**dual switch will only fit Gaffrig® Control
CLAMP-ON TRIM SWITCH DUAL FRONT MOUNT
Operate multiple drives or tabs separately
Front mounting allows for left or right hand configurations
Designed for Gaffrig® and Zero-effort Mercury controls only
Completely waterproof
Gaffrig ® switches must be installed at Livorsi® facility
Trim switch dual Gaffrig black FMTSGD $289
Trim switch dual Gaffrig white FMTSGDW $289
Trim switch dual Mercury black FMTSMD $289
Trim switch dual Mercury white FMTSMDW $289
(Will only work if throttle is canted forward, will not work on new billet straight handle throttles.)
From http://www.livorsi.com/cat_throttles.php
Ray
Raypanic is offline
Liquid Life
Do It Yourself, Boating on a Budget
3
06-17-2008 03:11 PM
BGIII
06-02-2005 12:44 PM
Slick02
06-01-2005 09:57 AM
THRILLSEEKER
05-26-2003 11:46 PM
SLINGSHOT
10-04-2002 10:56 PM
