28 skater 2XBB results....
28 4 blade Bravo-1 props.... 5600rpm max
1:36 to 1 drive ratio
no speedo:lift broke the dck of the speedo
conclusion: not as i expected,i think we made the canopy a bit heavier then we thought..
will post the pictures soon
is it posible you were really hauling ass and just didn't realize it becasue you were under a canopy?
i know 100 on my motorclcye feels a ****load faster than 100 in my car.
Pardon me, while I whip this out!
gps reading will be tomorow
my friend is also saying the same thing about under canopy stuff..
-do you think i should try bigger props?
-but i was dreaming 120's ..... ( oso family made me believe this )
anyway, will go faster soon
Nose weight (ballast) Did you put in that 150-200 lbs (=?kilos) as ballast forward? Be safe my brother............... I think the forum, builders, T2X and racers, 'NEED'(hope) you to follow their advice....... Balance!!! ............ Not just CG, but as Audacity has said 'MOMENT OF INERCIA' ie. 'Roll Center' . Best of luck, we are only looking after your best interest's!!!!!!!!!!
The props were 28"? with a 10% slip factor, and 5600 with 1.36 gears, I think you were running 98 mph. How much HP do you think the engines put out? Running the numbers, if your set up is anywhere near right, you are only putting out around 500 per motor. How high are the prop shafts?
Philip
Philip
Tim, did you run the boat today?? can you go over the set up again? I thought you posted it, if there is a post can you give me the link. If the engines are putting out more then 500 hp you might want to double check the height, and other measurements. toe on the drives, centerline of the shafts in relation to the sponson edge.
