burning rubber/plastic smell >
Old 05-19-2003 | 05:53 PM
cheitman
Default burning rubber/plastic smell
Finally took the boat out this year and made it back onto the trailer under her own power! New motor and drive performed great, however, noticed a burning rubber/plastic smell. I stopped and checked wires and felt the coupler rubber several times throughout the day and could not find anything out of the ordinary. I hammered it many times from a dead stop to see if it was the coupler giving out. Drove for about an hour total. When i got home I noticed the stickers on the on-board battery charger looked like they may have got warm. Plugged in the charger and it still works. I did acidentally leave the ac and charger switches on the shore power panel. I don't see how this would affect anthing though. Maybe it was just the Duipli-Color paint wearing off. The motor was only running 150 and the manifolds were cool. Any suggestions????????
Old 05-19-2003 | 08:01 PM
Burning rubber smell could be as simple as a loose belt.
Quest for Speed is offline
Old 05-19-2003 | 08:10 PM
New motor? New ex. man. gaskets? The composition gaskets that CMI sent with my new headers smelled pretty bad for the first hour or so running but I retorqued and everything is fine now. Even if the manifolds feel cool where the water runs through, they get damn hot at the port where they bolt to the head. Hope it's just that simple. --- Jer
jpclear is offline
Old 05-19-2003 | 09:16 PM
cheitman
The belts are all tight. It could be the gaskets. I sure hope so. If it was the coupler you sure would think that it would have let go after an hour of running. Or do they slowly give away?
Old 05-19-2003 | 09:45 PM
cuda's Avatar
It's been my experience that a coupler will let go all at once with no warning.
cuda is offline
Old 05-19-2003 | 09:46 PM
rjcardinal's Avatar
Same thing happened to me this spring. Over the winter I installed new exhaust. CMI's to be exact. The burning rubber smell was the header gaskets burning in. It became less noticable as the day went on and the next time out it was gone.
Ron
rjcardinal is offline
Old 05-19-2003 | 11:32 PM
I put 4 hrs on my new CMI's and can still smell the gaskets. I retorqued them today so hopefully it will go away now.
Griff is offline
Old 05-20-2003 | 07:24 AM
And when the coulper goes you don't usually smell anything, but the tow rope from your bow forward is a dead givaway. --- Jer
jpclear is offline
Old 05-20-2003 | 07:50 AM
cuda's Avatar
When my coupler went, it smelled and looked like someone was burning a pile of tires under the hatch!
cuda is offline
Old 05-20-2003 | 11:49 AM
cheitman
I did'nt see much smoke but that's the smell. In fact, the boat behind me smelled it too. Maybe i'll let the S.O.B. burn and call the ins. co. I would sure like to step up to a 312 Fastech! It would probably look too suspicious if the stereo and valuables were removed first!
