What prop do you recommend? >
Old 05-22-2003 | 07:19 PM
Elite Marine's Avatar
Default What prop do you recommend?
I was running a 29P Mirage Plus last year. Since the new motor is in I can't get the Mirage to bite without slipping or blowing out often.
Tried a 30P Lab Finished Bravo, great mid range acceleration and top end, but took forever and too much tab to get on plane, ran 4800 RPM WOT with the 30P.
Running a 28P Hydromotive right now, great out of the hole, good acceleration and decent top end, 5000 RPM WOT. The downside to this prop is that it really causes the boat to porpoise.
The boat is my 24' Pantera, 4,500#, 645HP, 1:50 Bravo
From the above info, what do you recommend?
Elite Marine is offline
Old 05-22-2003 | 08:59 PM
REDCHECKMATE's Avatar
What was last yrs hp and speed and rpm's with the 29plus. Also what is the rpm @645hp.
REDCHECKMATE is offline
Old 05-23-2003 | 06:32 AM
I think I would try to get a 28 lab to try. It sounds like the 30 is to much wheel and the 28 Hydro isn't carrying the boat quite right. Probably from the calculations I ran both of these are probably getting you into the high 70's. If you can swing the 28 lab 5200 RPM it may put you around 80. What rpm did the motor make its best HP? That may help get you into a pitch and the correct prop will be determined by testing.
WETTE VETTE is offline
Old 05-23-2003 | 07:41 AM
Dave M's Avatar
Veteran: Navy
I have a 24 Superboat which has a very similar hull as the 24 Pantera. I had the same problems you describe with the Mirage plus. I have a 454 Mag (385 HP) and I run a 26 Bravo @ 5000 rpms. With as much HP as you have I would think a 28 bravo would be too small. Are you sure your boat weighs 4500? Is that including gear, gas, and people? I would think with 645 HP you should be around 90 MPH.
Dave M is offline
Old 05-23-2003 | 05:35 PM
bobby daniels
I'm like wet vette I'd go with the 28 bravo and let the motor turn its loaded to death now I think
Old 05-23-2003 | 05:39 PM
Boat should be around 4600# with me and 1/2 tank of fuel.
I was running Mid 80's with the 28P Hydromotive @ 5000 RPM.
With the 29P Mirage last year . . . . 91+ MPH. I don't remember the RPM though!!
Old 05-24-2003 | 07:16 AM
HOUSTONPROP's Avatar
Lightbulb thick trailing edge
the thick trailing edge on the hydro causes stern lift by thinning this out this may stop most of the porporsing./Darin Houston propeller
HOUSTONPROP is offline
Old 05-24-2003 | 07:17 AM
Default Re: What prop do you recommend?
Old 05-24-2003 | 08:35 PM
Trying a 28P Stern Driver tomorrow. Nobody around here has a 28P Bravo to try...Anyone on OSO have one I can try?
Thanks,
Kirk
barry d.
14
06-08-2008 02:20 AM
chuckd1025
11-07-2007 05:55 PM
Megabite
Prop Talk
1
05-30-2007 12:28 PM
flatout
0
06-02-2006 02:09 PM
Dave M
02-03-2002 05:37 PM
