Bravo one oil consumption??? >
Old 05-26-2003 | 10:20 AM
JS232's Avatar
Default Bravo one oil consumption???
I have a 2001 bravo one drive.
First season out last year ( 100 hrs ) I had to fill drive lube monitor 4-5 times last year. (Used 1/4 of a bottle of quicksilver high perf. gear lube over the season. Dealer says it's normal on some drives. They checked it over the winter and the seals looked OK. No water in oil. Warranty ends in 7 days... Should I trust in my dealer or should I require more ???
JS232 is offline
Old 05-26-2003 | 10:32 AM
CESSNA
That oils going somewhere and make sure he writes it up and gives you a copy and puts one in your file ,that way when it breaks you can go back to him with proof its not normal on any of my stuff over the years
Old 05-26-2003 | 12:21 PM
Kanookstr's Avatar
32' SUNSATION
Check where the ruber hose from the res bottle connects to go thru the transom. I had a boat where I kept having to refill the res. but the outdrive tested fine. it was leaking at the barb where it goes thru the transom. I put a hose clamp on, and the oil consumption stoped...
Kanookstr is offline
Old 05-26-2003 | 12:51 PM
JS232's Avatar
Good idea... I'l check it out over the week-end.
JS232 is offline
Old 05-26-2003 | 12:57 PM
Strip Poker 388's Avatar
Rob
I had one that leaked out at the prop shaft seal . need put a presure tester on it.
Strip Poker 388 is offline
Old 05-26-2003 | 04:53 PM
Team Gary
Do you see any green oil in the bildge? That should tell you if it's leaking inside the transom or outside.
Old 05-26-2003 | 06:18 PM
bowtie's Avatar
Its not normal. Its a sealed unit, does not burn oil so how does it consume oil. I would check the fittings from the bottle to the transom. If they did in fact pressure test the drive, and it holds pressure, that leaves only the monitor and plumbing to it to leak.
bowtie is offline
Old 05-26-2003 | 09:57 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I had the same thing on last boat. Pressure tested and vaccum test the drive. Nothing. Also no leaks in the bilge, nor ever see any oil slick while in the water. Never could find anything. Also replaced the whole drive last summer with a brand new one. Same thing. Would have to add some oil to the reservoir bottle approx. every 2 months. I just chalked it up to nature of the Bravos and ran with it.
US1 Fountain is offline
Old 05-27-2003 | 05:17 AM
Replace the O-ring #4, 25-457101 that goes on the drive shaft housing. This is the O-ring that seals the drive shaft housing to the transom for the overflow. It can leak when the drive heats up and forces oil into the reservoir. Leaking there is hard to find as it only leaks when you are running and oil will be washed off by a drive shower or water from exhaust tips, spray etc. Sometime you will see a slight film of oil when you first stop.
BadDog is offline
Old 05-27-2003 | 06:07 PM
mopower's Avatar
Toxic FORMULA
I had a 2002 last year(brand new) that was losing oil only when I ran it. It would sit in the driveway all week and stay full. Checked everything . Finally tried tightening the bolts between the upper and lower gear cases on the drive. Got about an eighth of a turn on each bolt...leak stopped
mopower is offline
