Go Back  Offshoreonly.com > Owners Forum > Nordic
Trailer & tow vehicle tire PSI >
Old 05-29-2003 | 06:19 AM
Mr. Gov'nt
Default Trailer & tow vehicle tire PSI
I am going to be towing my 28 Heat 750 miles next month and my question is do I keep the boat trailer tires at max PSI which is 50 and tow vehicle a Chevy Tahoe at max PSI which is 35?
Old 05-29-2003 | 06:35 AM
birdog's Avatar
Yep..........Always.......
birdog is offline
Old 05-29-2003 | 07:18 AM
Indy's Avatar
Member #154
What Birdog said...
Indy is offline
Old 06-13-2003 | 09:43 PM
dropthehammer
Are you worried about the weight at all over that distance? The Tahoes are rated for 5000 lbs and you are probably a little over 6000....
Old 06-16-2003 | 11:13 PM
Are you sure the max PSI on the Tahoe is ONLY 35?!!! If so, you should really check the load rating on those tires.
Chart is offline
BL6
20
09-16-2007 11:33 PM
dukenrock
23
01-05-2006 09:57 AM
aTX427
Fountain
9
10-07-2003 12:19 AM
rouxsterre
05-02-2003 07:09 AM
CheckmateF1
01-22-2002 11:05 PM
