2much exhaust heat! what does it mean? >
Old 05-29-2003 | 07:06 PM
timucin's Avatar
Default 2much exhaust heat! what does it mean?
2 much heat on exhausts. what does it mean?
left side engine's gets twice hotter then the other side
what can be the reason
timucin is offline
Old 05-29-2003 | 07:25 PM
blue thunder's Avatar
I am assuming you mean hot to the touch. If so, and you have thru hull exhaust, is the water exiting a fairly even volume from side to side? If you mean hot on EGT gauge, never mind.
BT
blue thunder is offline
Old 05-30-2003 | 07:07 AM
Zanie's Avatar
EGT Hot = Too Lean!
Zanie is offline
Old 06-01-2003 | 08:54 AM
bodacius
WATER RESTRICTION , DEPENDING ON WHAT TYPE OF COOLING SYSTEM, .
imartin
Nordic
4
12-08-2006 03:42 PM
Rage
Nordic
3
11-14-2005 09:36 PM
boatfreak
4
08-21-2005 10:25 PM
Madmax
Nordic
2
02-07-2004 12:58 PM
