gas quality for initial start up? >
Old 05-30-2003 | 10:50 PM
Default gas quality for initial start up?
I was under the impression that my boat w/about 40 gal or gas in tank was going to be stored in a heated barn over the Ohio winter while upholstry work was being done
Well......it turned out to be an open air barn so now I am concerned about water in my fuel for initial start up on two rebuilt engines. I have never had to deal with water in fuel and I am always hearing about how initial start up and break in is critical to engine life, so should I drain all the fuel from the tank before starting........add some stabilizer and use it,......or just say the hell with it and do nothing
THRILLSEEKER is offline
Old 05-30-2003 | 11:29 PM
I'd drain it and start with some fresh fuel......just my .02
88 MACH 1 is offline
Old 05-31-2003 | 12:25 AM
mcollinstn's Avatar
If you didn't add stabilizer, it is too late to add it now.
Drain the contents of your water separators and fill them with fresh gas and put them back on.
After the first 5 minutes of running, drain them and refill them again. It is helpful if you drain then into glass pickle jar so you can look for water blobs.
If its clean, then you're prolly ok.
If not, keep draining the separators every now and then in increasing intervals.
After you run the whole tank empty, refill and put on NEW separators.
mcollinstn is offline
Old 05-31-2003 | 07:09 AM
MACDAD260's Avatar
Charter Member #818
Was the gas cap open? As long as everything was closed like it normaly would be you should have nothing to worry about. How long was the boat stored? If it was just the normal winter layover the gas should be OK even if you did not put stabilizer in it.
MACDAD260 is offline
Old 05-31-2003 | 09:17 AM
I have recently purchased a 302 Formula that had been sitting for 2 yrs with 70 galons of fuel. I put in 4 bottles of fuel stabilizer filled with 94 octane gas approx 30 gallons,checked for water.(in 5 gallons of fuel removed,there was only about 2 tablespoons of water) changed my seperators. I have burned through about 65 gallons of fuel now with only one or two higher RPM stumbles. Today I plan on changing the seperators again. Good luck I've been lucky so far! Andy
Andy is offline
HabanaJoe
04-24-2008 10:53 AM
Wobble
34
05-04-2005 03:08 PM
Nordicflame
18
03-22-2004 11:22 AM
convincor
6
06-16-2003 06:35 PM
THRILLSEEKER
1
05-31-2003 12:30 AM
