New prop - different thrust washer ? >
Old 06-02-2003 | 03:49 PM
duunoit's Avatar
Default New prop - different thrust washer ?
I went to change my prop this weekend and ran into a little problem. I was replacing a Mirage/solid hub with a Bravo I/flo-torq hub. There is a ring that is about a 1/2 inch thick(I assume this is the thrust washer) at the back of the shaft. When I put the thrust washer from the flo-torq and then the propeller on the shaft the prop sticks out from the outdrive about a half inch. I tried to pull if off but couldn't. I'm going to grab a bearing puller tonight and give that a shot. Anyone have any ideas?
duunoit
duunoit is offline
Old 06-02-2003 | 09:58 PM
Tinkerer's Avatar
put a block of wood between the drive and the thrust washer and then a big screw driver and just pry a little -- it will pop off.
Tinkerer is offline
Old 06-06-2003 | 01:36 PM
duunoit's Avatar
I tried the gear puller last weeked with the boat in the water. I managed not to drop any thing in the water, but didn't get the washer off. I pulled the boat today and went at with a crowbar and a rubber mallet. One tap and (cling) off it came. It was definately the thrust washer, but it was only about a inch in diameter as opposed to the one that I replaced it with that was about 2 inches.
duunoit is offline
BajaRunner
13
07-18-2006 09:01 AM
onesickpantera
Prop Talk
4
05-19-2006 07:53 AM
1BIGJIM
Prop Talk
3
05-09-2006 09:30 AM
1BIGJIM
1
05-08-2006 12:34 PM
kook
1
06-17-2002 12:09 AM
