Alignment Tool-Where to buy? >
Old 06-16-2003 | 03:41 PM
liquid lounge
Question Alignment Tool-Where to buy?
preferably in the midwest...I'm in KC....for Bravo....and at a decent price of course Thanks in advance
Old 06-16-2003 | 04:02 PM
blown formula's Avatar
Try ebay first....
blown formula is offline
Old 06-16-2003 | 04:30 PM
KCHOTBOAT's Avatar
Charter Member #737
If you know Doug Fisck(sp) in Lee Summit he had a guy make several for him at a machine shop. There also was someone on the board making and selling them.
KCHOTBOAT is offline
Old 06-16-2003 | 11:44 PM
formulaF302
use your search engine to go to "mercstuff". He makes them himself, is a hell of a machinist and honest as the day is long....and sells other mercstuff and great prices too. He even de magnitizes them vefore shipping. I can't say enough good things about how good he treats customers and how good his prices are...his name is Mike....I've known him for about 20 years... Glenn
Old 06-17-2003 | 09:14 AM
liquid lounge
Default Thanks Formula 302
Thanks for the heads up...I just ordered it - got a good price of $66.95...and best of all, I'll have it in two days since they are in Michigan. Thanks again, Berg
Old 06-17-2003 | 01:09 PM
Wally's Avatar
Were doomed!
mmmm.....theres one on ebay right now....
http://cgi.ebay.com/ebaymotors/ws/eB...category=26455
-Wally
Wally is offline
Old 06-19-2003 | 04:51 PM
Thumbs up
http://www.mercstuff.com/page14.htm
FAST ENOUGH is offline
Old 06-20-2003 | 10:06 AM
liquid lounge
Well, I received my tool...really nice with knurlized handle. Now if I could just get the FU@#$NG thing aligned...man, am I PISSED....it has to be the coupler splines...Has anyone ever done this by themselves turning each motor mount 1/2 turn at a time all the way up...getting in and out of the boat after each 1/2 turn!!!!I feel like JayL13!! I was so depressed, I couldn't even drink a beer. The only odd thing that I could see is that the rear mounting bolts that attach the the motor to the transom plate are about a 1/4" differnt in height, but are both torqued down and there is no gap where the leather washers are.
I suspected that I might have an alignment issue because the drive didn't slide off that easily...I don't see any aluminum particulate to speak of on the tail splines....2 years old , low hours, moderate power [415hp]. Anything I'm missing? Thanks in advance, Berg.
Old 06-20-2003 | 10:21 AM
liquid lounge
I may have figured it out as I was eriting the first post. Both the transom mounting bolts when fully seated and torqued, should be stick up the same amount, right? If not, then the engine would lift or lower at the back mount when adjusting the front mount...making the motor out of kilter, I hope??!! Only thing is, both bolts seem torqued
Old 06-22-2003 | 11:15 PM
formulaF302
I assume you have good unbroken springs under each one correct? If you get a good reading with the tool, and then rotate the engine 180 degrees and get a bad reading you have a blown coupler.....and thats a tip from experience....
CULATER
Ft Myers Offshore
4
03-14-2008 11:10 AM
Ken N
4
10-25-2007 09:46 PM
tmdog
11
03-27-2005 07:52 PM
Raypanic
14
05-19-2002 01:16 AM
blackhawk
05-13-2002 07:29 PM
