Thermostat cover gaskets leaking water >
Old 06-18-2003 | 07:05 AM
Just installed my new t-stats, asn housings, used merc gaskets and plenty of Ultra Black. and when I turned the hose on water came pissing out between the housing and the top cover
I since then removed the t-stats and drilled a hole in each one so there isnt is much pressure on them.
Should I try to re use the merc gaskets (still in pretty good shape)
or cut my own from a thicker material??
Also should I use sealer on this or not??
Thanks in advance
THRILLSEEKER is offline
Old 06-22-2003 | 03:16 PM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
Default pissing-o-plenty
Thrill, was the sealant cured?
martiniboat is offline
Old 06-22-2003 | 06:30 PM
bobby daniels
a chevy gasket will work and be sure the thermo is in the grove it fits in and t silicone is cured before starting ,,,the silicone will work by it self also
Old 06-22-2003 | 11:06 PM
formulaF302
Hey wait guys....I thought a special mercruiser gasket was required there which had a conductive strip on it so that your temperature overheat alarm would work in case of an overheat.....has this part been changed or is everyone ignoring their overheat alarm in the thermostat housing???? Glenn
Scarab3DMC
11
09-02-2008 12:58 PM
CN24
7
12-23-2004 06:19 PM
klaw
1
11-07-2004 06:08 PM
Rambunctious
5
05-17-2004 12:20 PM
IRONMAN
4
01-31-2002 06:26 PM
