Outdrive Gear Ratio Question
What props are you running now? What RPM & speed? With the motors you have & 1.5 gears, I would not think that you need any bigger props than 32 or 34's. As stated above only need to go to 1.36 gear ratio is when you can not get a prop that is big enough. You can now buy props up to 36". Why is your builder telling you this?
Official OSO boat whore
I'm told that a (numerically) higher drive ratio and a taller prop will accelerate faster than a lower drive ratio and smaller prop. Why that is, I don't know.
