Trim pump ports >
Trim pump ports
Trim pump ports
Old 06-20-2003 | 08:05 AM
Official OSO boat whore
Default Trim pump ports
When you look at the trim pump, which port is which? Which port is up and which one is down?
Cord is offline
Old 06-20-2003 | 10:22 AM
Nobody?
Cord is offline
Old 06-20-2003 | 11:00 AM
Hook em one way, if it doesnt work then switch em
THRILLSEEKER is offline
Old 06-20-2003 | 11:36 AM
Hense my problem!
Cord is offline
Old 06-20-2003 | 12:08 PM
rws's Avatar
rws
I don't know off hand which port is up,But.The Blue wire should be the one that makes it go up.High pressure.hook them up and energize the blue wire to be sure .Switch the line if it is not correct.
Rob
rws is offline
Old 06-20-2003 | 01:07 PM
Rob
That's pretty well what I'm facing. It was working just fine until it was pointed out that I had the blue wire on the bottom solinoid. I realize that it doesn't really matter which wire is connected where, but instead it's the ports that matter. It wouldn't be such a big issue if my lines were long enough to be reversed.
Cord is offline
Old 06-20-2003 | 05:07 PM
David's Avatar
If you have the white plastic reservoir pump, the hose fitting connx are marked on the pump housing with an arrow above the fitting. On the round cannister type, up is on the right if you are looking at the fittings. Square pump, up is on the bottom left with the filler screw on the right front.
David is offline
Old 06-20-2003 | 07:34 PM
FORDSS0
Black hose is up. Gray is down. Looking at the pump left hole is up , right hole is down ......
Old 06-20-2003 | 08:39 PM
Thankyou david and ford. Thats the answer I was looking for!
Cord is offline
CNC
2
06-10-2006 07:36 AM
ratman
01-26-2006 07:48 PM
Poorsche
2
04-23-2005 06:48 PM
Phantom1
04-11-2005 11:05 AM
