Alternator Bracket Needed
Have a 87 Baja 280 with twin 454s. The lower alternator bracket has broken. I have had it welded but it broke again a year later. I want to replace. Any idea what application I need to look for at a salvage yard?
JimmyBaja,
Alot of these brackets crack if the alternator isn't tight enough. It sits back there and vibrates. Check to see if you have a washer in the alternator bracket. At the top where the long bolt goes through there should be a washer against the front of the alternator as the bolt goes through. This stop the alternator from loosening and wearing out the front top of the alternator housing. The part # for a new Mercruiser is #85013t. It list for around $30.00. The only problem about getting a used one is it might be on the edge of cracking and you not see it.
If you have any questions or need further help, feel free to give me a call at the shop.
Pwrbt33- John S.
OffshorePerformance
1-877-GOFAST1
Pwrbt33- John S.
OffshorePerformance
1-877-GOFAST1
Anarchy Powerboats
03-15-2007 03:24 PM
