water pickup for inter cooler >
Old 06-20-2003 | 12:43 PM
Hot Boat's Avatar
Team Dysfunctional
Default water pickup for inter cooler
what is the best water pickup for a small inter cooler. Also where should it be mounted. This is for a single engine boat. currently i am using a pickup similar to that on a drive shower but larger mounted on the cavitation plate. It is working fine until WOT. at 4700 rpm I get 8 psi but at 5200 I get 0 psi.
Hot Boat is offline
Old 06-20-2003 | 01:02 PM
Sounds like it's coming out of the water. Either longer pickup or move it to the bottom of the transom. That's where mine is.
zahndok is offline
Old 06-20-2003 | 01:05 PM
Official OSO boat whore
Imco makes one that has an adjustable cutting edge. It looks very simular to the Stainless Marine pickup. You need the adjustable edge to dial in the pressure.
Cord is offline
Old 06-20-2003 | 04:43 PM
bobby daniels
iTS BEST TO HAVE THE SAME OR MORE WATER PRESSURE IN THE INTERCOOLER AS BOOST LEVEL AND i PUT THEM ON THE TRANSOM FROM STAINLESS MARINE AND TRIM THEM
Old 06-20-2003 | 07:39 PM
What's everybody's opinion about a separate pickup for the intercooler vs. teeing in after the sea water pump?
tomcat is offline
Old 06-20-2003 | 08:14 PM
Why drag something else thru the water?
cobra marty is offline
Old 06-20-2003 | 08:34 PM
I'm told that the standard pickup isn't capable of supplying enough water to both the engine and the cooler. You also want the cooler to not receive water when off plane. If prevent a vaccume break, it would have to be teed in after the water pump, so the cooler would always see water.
Cord is offline
Old 06-20-2003 | 10:56 PM
REDCHECKMATE's Avatar
I run all the water from sea water pump thru oil cooler then thru intercooler.
REDCHECKMATE is offline
Old 06-22-2003 | 10:22 AM
Tantrum's Avatar
Aretn you then trying to cool with warm water?
I would think the results would be better with a seperate pick-up or atleast pick it up before the oil cooler.
Hotboats pick up is also runing on the right side of the cav plate w/ a right hand prop (drive shower is on left). I thought there might be a problem when it was being hooked up.
I would go with the transom mount.
Tantrum is offline
LZH
Drives and Lower Units
0
02-25-2008 08:18 PM
dualprop
09-11-2006 02:34 PM
TSNAVE
09-26-2002 07:41 PM
Hot Boat
11
07-25-2002 09:50 PM
