Serpetine belt with water crossovers problem. >
Old 06-25-2003 | 02:20 PM
GNJ2
Question Serpetine belt with water crossovers problem.
I bought 2 water crossover kits to eliminate the recir. pumps for my twin engine 502MPI Fountain. The problem is: if I remove the waterpump with pulley, I can not figure how to get the serpetine belt to contact the crank pulley. Is there something I am missing such as a replacement pulley/bracket to get the same belt configuration as before? The crank pulley will not touch the belt if I use a smaller length belt. Help please!!!!
Old 06-25-2003 | 10:10 PM
DonMan
I just installed a crossover on my 7.4 MPI (with serpentine belt). You MUST buy a crossover that is designed to work with a serpentine belt. I found mine at CP Performance. It came with all hardware plus a thermostat housing that eliminates the big ugly original. Cost was $489 plus shipping. I wish I had a photo to show you, but I have yet to take any.
Hope this solves your dilema....
Old 06-26-2003 | 01:31 AM
Excuse my ignorance here, but, when you remove the circ pump, what runs the water thru the engine then? Is there a different pump, or does the seawater pump take care of it?
dumbguy123 is offline
Old 06-26-2003 | 02:23 AM
Yes, the sea pump takes care of it.
Griff is offline
Old 06-26-2003 | 06:59 AM
GNJ2
Talking watercrossovers
OK thanks very much Donman & Formulafastech. You are lifesavers. Eddie Marine is going to take the two sets I bought from them back.
Old 06-26-2003 | 01:07 PM
Krumbsnatcher's Avatar
Talk to Mike at CP Performance and tell him Jeff sent you, he has helped me build my 540 from the blower to the carb.
He knows his stuff and he builds custom stuff too.
Krumbsnatcher is offline
pullmytrigger
14
06-28-2008 06:45 AM
31scarab31
11
03-04-2008 02:14 PM
kidapache
Wanted
1
02-21-2008 01:28 PM
VIPER7
29
03-26-2005 12:34 AM
US1 Fountain
10
05-22-2002 06:04 PM
