Teague 509" crate motor
I have a boat the needs repowering, and was looking to add a new 496, but after flipping through Powerboat I noticed that Teague Custom Marine had a 509" 575 hp motor for 9995.....that is CHEEP.
Has anyone run one of these, how do they last?
Thanks for any info.
RT
RT
This is what I found...
Horsepower:620 HP
Displacement:509 c.i.
Recommended Max WOT RPM Range:5,600 - 5,900
Block:V-8, Merlin II or GM Bowtie, 4-bolt main, 9.800 deck height
Crankshaft:5140 HP forged steel
Connecting Rods:Manley or Carrillo (on request)
Pistons:Custom J.E. forged aluminum
Rings/Bearings:Speed Pro/Hastings/M-77 H Series
Cylinder Heads:Merlin VR Heads, rectangular port, flowported, match ported, bronze guides,
A R PPro Series Studs, and Crane guide plates.
Valves:Manley SS and Inconel Valves (extreme duty)
Induction System:Brodix intake manifold/Holley Dominator 4-barrel carb
Valve Covers:Teague polished aluminum w/breathers
Ignition:Complete MSD Marine Ignition with Soft Touch Rev Control
Camshaft/Valvetrain:Custom Crane hydraulic rollercam and lifters, Manley pushrods
and Crane rocker arms.
Exhaust:CMI water-jacketed tubular stainless steel, polished E-tops with cool collar
(specify optional tailpipes)
The TCM 620 HP Package also includes:10 qt. Gil oil pan, custom engine wiring
harness, warning system, ATI damper, billet pulleys, flame arrestor, all MerCruiser
accessories — this engine is ready for installation!
Necessary BoatUpgrades:
fuel system.
Offshore oil cooler, hi-volume sea strainer, and modified
TCM also recommends:External hydraulic steering, Teague “Platinum Series” Bravo
Drive upgrade,Teague ST-450 switchable muffler tips, performance propeller upgrade.
Long block and short block versions of this engine package are available without warranty
Horsepower:620 HP
fuel system.
My buddy has a teague motor and it lasted 10 minutes but then he did go 108 for those fun minutes before he blew a motor and and XR drive.
Paul Pfaff builds a really nice motor, but you get what you pay for!
firewalker I thought it was a good deal until I found out what it is . You can call summit and ask for a world products crate motor
add a pan and 741 crane roller and add a marine merlin intake and you have their motor ,,,my supplier said don't use it so He turned down a sale and I trust his judgement
