EFI VST - fuel preasure >
Old 07-02-2003 | 06:37 PM
maverick1
Question EFI VST - fuel preasure
I'm running a 1995 502 EFI with the VST tank. I am concerned about WOT fuel pressure as my boat (I think) could run stronger @ WOT. I know there is a fuel pressure tap at the front of the intake manifold, but where can you rent, borrow or buy a gauge that will attach to that "Schrader Valve" without a serious risk of leaking while under power -- WOT power???
I borrowed a fuel pressure gauge from a local mechanic's shop and did get a key "on" pressure of 42 lbs - with a quick leak down once the key cycled off -- only to discovery the guage "tap" was leaking at the connection to my motor and spewing raw gas into my bilge?!??!?!?
Help........
MAV
P.S. What pressures should I find an hold at WOT????
Old 07-04-2003 | 10:13 AM
mats's Avatar
If you disconnect the vacuum hose connected to the regulator , the pressure should be completely steady at all rpms and the same as it is when you just turn on the ignition. If you know a merc mechanic somewhere, they usually have a very good merc fuelpressure gauge that does not leak.
mats is offline
snake plissken
3
06-07-2007 08:24 AM
Donzi502
2
09-30-2006 10:58 PM
Ted G
11-05-2005 08:57 AM
pachangalpina
1
07-06-2004 09:58 AM
H2Xmark
7
08-04-2003 10:48 AM
