TRS - Drive oil leaking around inner gimbal housing
I've got a pair of TRS drives making a mess of my bilge. The leak trickles down the transom under the dip stick/reserviour area. I just had the the drives off this winter and replaced both of the pass-thru seals.
If these were dinged putting the drives back on, where will they leak? No evidence of water in drive when refilling from lower port.
Here's a picture.
Thanks,
Brian
Here's a picture.
Thanks,
Brian
Hey- How is Gibraltar doing these days? I used to live there about 20 years ago. Corner W. Jeff & Gib Road.
I normally put some red silicone around where the seal is (on drive gasket), and I would make sure the hose is not leaking between reservoir and fitting to gimbal. It is possible to overfill and leak from the vent. There is also a chance you may need to replace the reservoir gasket. Last but not impossible, hope there is no corrosion on reservoir between inner plate and transom.
Thanks David,
I keep hearing from local mechanics that the oil seal around the "connector nipple" is very delicate, and just touching one with the nipple during drive instalation can cause this leak. I was very careful and have changed them twice to try to stop this leak.
I will also try some gasket sealer on the drive gasket around this opening to see if that helps and change the oil seal AGAIN. I don't have any apparent corrosion problems with the inner gimbal housings, and I'll live with the mess until this winter if I need to pull the gimbal housings to check seals there.
I also inspected the hose for tightness and damage last time the engines were out - this spring.
Gib is growing, but still maintains a small town charm. People are going crazy with the money they're spending on homes here - buying two adjacent homes, then whacking them both and building 4-5000 sq ft homes with nice frontage. We're on the first island in from Horse. (the main island, same one Humbug Marina in on).
Thanks for the tips.
Brian
Brian
Velocity Tom
07-16-2003 10:13 AM
