Merc water-pump-mounted fuel pump >
Old 07-08-2003 | 12:44 PM
Cignificant's Avatar
Default Merc water-pump-mounted fuel pump
Does anyone know the part number for these? Or even better, does anyone have an old one you want to sell? All I really need is the pump-arm assembly.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 07-08-2003 | 02:55 PM
cig1988's Avatar
A friend of mine has 2 from mercruiser brand new never used way below list. You can either email/pm me. I posted the ad in "parts for sale" and I'll TTT for you. His ph# is there unless you want me to call him for you. Hope this helps you out.
cig1988 is offline
Old 07-08-2003 | 09:08 PM
Sorry, I need the fuel pumps, not the sea water pumps...
Steve Gresham
'03 Donzi 33ZX
Old 07-08-2003 | 09:30 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Steve,
Pt # 861677T. This was for my GenV HP465/502.
I bought a new Merc pump a couple yrs ago because I thought the diaphram was leaking do to a gas smell in the water pump oil reservior. It appears it is just a normal thing as I see alot of people say same thing. Gas was never in the sight tube, so I suspect it was never bad. I used the new pump arm half only and retained the other half as it was drilled for larger fittings.
I still have the used pump arm mounted on the brand new/never used bottom half.
$50 to your door.
US1 Fountain is offline
Old 07-08-2003 | 09:39 PM
O.K. heres my window to ask about the res. what oil...how much...and how do you check. My bad I know, but in 400 hours I have done nothing . the fill plug is in the side of the body..do you squirt some gear oil in there till it runs back, like a bath/diff. ? Help?
Rippem is offline
Old 07-08-2003 | 09:47 PM
Ginger or Mary Ann?
Merc Hi Perf Lube oil, (outdrive oil) 1/2-3/4 cup????? Not much.
Mine had 2 plugs (upper and lower) on the side facing out. Fill till it runs out the upper plug.
I always removed the fuel pump and drained the oil out completely a couple times a yr and refilled thru the fuel pump opening until even with the bottom of the top plug. The lower plug won't drain all the oil.
Old 07-09-2003 | 07:28 AM
Thanks, I need to get on this before they ****z......
Rippem is offline
Old 07-09-2003 | 10:09 AM
US1 Fountain, check your email...
Steve Gresham
'03 Donzi 33ZX
Old 07-09-2003 | 06:21 PM
GO4BROKE's Avatar
The newer style pumps don't have the lower hole, just the upper. Have to be removed to dump out the oil. I tried to suck it out, doesn't get enough.
[img][/img]
GO4BROKE is offline
BillR
11
07-29-2022 06:31 AM
BillR
27
08-10-2008 11:31 PM
jdub
7
03-26-2007 05:06 PM
BillR
4
02-06-2007 03:23 PM
Thunderstruck
0
07-25-2006 01:10 AM
