Looking for 6 psi of boost >
Old 07-08-2003 | 08:21 PM
Hot Boat's Avatar
Team Dysfunctional
Default Looking for 6 psi of boost
well after 20 successful hours and one poker run I am ready to tune the motor. I had the motor de tuned a bit so that I could break it in . The motor was set up to run at 30 degrees timing and 6 psi of boost . I been currently running 28 degrees timing and 4.5 psi boost. What I need to know is what size pulley I need to get 6 psi. . The motor is a 454 with a 177 weiand blower with a inter-cooler. I am currently running the standard pulley that is supplied with the blower. There is about 4 other pulleys to choose from but I don't know where to start. any one have a clue?????
Hot Boat is offline
Old 07-08-2003 | 09:07 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
next pulley smaller=spins blower faster=more boost
US1 Fountain is offline
Old 07-08-2003 | 09:47 PM
Hi Paul.
The Holley manual lists a 7" lower pulley with a 3.07" upper pulley. This combination should be approx. 6 lbs of boost on a 454 with a 177 supercharger.
Dave
dckrafft is offline
Old 07-09-2003 | 12:30 PM
Hot Boat's Avatar
Team Dysfunctional
Thanks dave. let me know when you are going on the river again.
Paul
Hot Boat is offline
Old 07-09-2003 | 07:27 PM
I will give you a call if I plan on going out. Boating has sorta been put on the back burner for the time being.
Take care.
dckrafft is offline
k24u
4
06-20-2006 09:55 AM
custom29scarab
4
08-08-2005 02:47 PM
gripit
6
12-11-2004 05:18 PM
Mad Hatter
08-10-2003 11:55 PM
BigJake
5
07-08-2003 12:07 PM
