Carb Base Gaskets >
Carb Base Gaskets
Carb Base Gaskets
Old 07-09-2003 | 03:49 PM
BAD-HABIT's Avatar
Default Carb Base Gaskets
I was wondering what the difference is between the Holley 4-hole base gasket and the open one. In my rebuild kit it only came with a open gasket....I bought a 4-hole spacer and I got 4-hole base gaskets with it...
BH
BAD-HABIT is offline
Old 07-11-2003 | 05:38 PM
220BR
IMHO, if we're talking the paper thin gaskets, 4-hole versus open will make little if any difference.
If we're talking a spacer or an insulating gasket (1/4" or thicker), then the general rule is that an open gasket/spacer will move the torque peak higher in the rpm band and/or reduce the peak torque. Whereas a 4-hole, will benefit low-end torque compared to top end.
General rule of thumb only.
Old 07-11-2003 | 06:35 PM
BAD-HABIT's Avatar
Strickly talkin about the gaskets....
BH
Nordicflame
12
07-17-2008 10:27 AM
ofshore
1
04-17-2005 07:53 PM
BAD-HABIT
3
05-29-2004 01:02 PM
BAD-HABIT
1
08-28-2003 07:07 PM
cheitman
2
12-23-2002 10:22 PM
