Pulse Drive vs Arneson ?
Old 07-10-2003 | 07:47 PM
Byron
Default Pulse Drive vs Arneson ?
Just asking what everone thinks about these two drives. I've picked the Arneson setup on my new Spectre 36' over the Pulse. The pulse looked to bulky and add on. I thought the Arneson was a cleaner look and a more experienced company. Just wondering your thoughts.
Old 07-16-2003 | 09:43 AM
GEOO's Avatar
1975 X-18 Donzi, Arneson
Arneson, proven, been around a long time, larger network world wide dealers & suppliers, easy to get parts. Many sizes and custom parts available.
GEOO is offline
Old 07-16-2003 | 11:04 AM
Charter Member#350
Remember that my Pulse Drive looks "bulky" because it is a double shaft/propeller system. In your case it is going to be a single system on each side.
If your engine hatch opens to the sides (split engine hatch) you can actually step into the Pulse Drive to look and work on the rear section of your engines.
The swim platform and the rudder of the Pulse Drive will protect your propeller if you go to shallow or if you hit a marina wall going in reverse.
Catmando is right on his comments and the last reason is (look at photo)
Zero Cavity is offline
Old 07-16-2003 | 11:26 AM
The pulse looks to be a simple, straitforward design. Anyone in boating has to like that.
My only concern id the tranny. The arneson transfers trust to the transom. The pulse puts the trust on the tranny. These tranny were made to handle that, so that's not the problem.
My question relates to the trimming mechanism design. The pulse looks like it puts the Ujoint on the tranny output flange. This will result in some off center thrust being transferred to the tranny. Most IB tranny are only designed for thrust parallel to the output shaft. For those who have worked in IB boats, prop shaft misallignment results in a similar situation. The result of that is premature output bearing and seal failure in the tranny.
I would just check with the tranny manufacturer would reccomend this type of installation.
My $0.02
Gary
Gary Anderson is offline
Old 07-16-2003 | 12:08 PM
dreamboater's Avatar
Are these drives priced similar to each other? How do they compare in price to #6?
dreamboater is offline
Old 07-16-2003 | 01:00 PM
GregP's Avatar
They are both essentially FREE if your comparing to a #6 drive
-Greg
GregP is offline
Old 07-16-2003 | 01:10 PM
BLee's Avatar
Charter Mod
-Greg
LOL They can also handle more power than a 6.
BLee is offline
Old 07-17-2003 | 04:22 PM
PULSEDRIVE
Gary
The problem with a misaligned IB drive shaft is the vibration not the off center trust, running through a single Ujoint minimizes vibration, saving the bearings and seals on the tranny.
99% of all our applications are run with ZF trannys, Hi HP applications we have Huber up grades done to the ZFs
All come with full warranty
Pulse Drive makes 23 different drives.
Drives come in singles, twins, triples and quads.
Parts are carried in 32 different countries and adding everyday
our engineering team have been working with surface drives since the '60
If anyone has any questions feel free to contact me directly
Tony
954 788 0810
Old 07-17-2003 | 04:38 PM
Steve 1's Avatar
Another point is the Horsepower Loss on a # 6 what would be the prop-shaft Horse-power of say a 600 HP engine
560-550 ? thats a big price to pay ..also on those toy bravos that need the water cooling whats that all about?? LOL Oh do you know heat generated by friction is the most costly..That BTW in terms of required energy input.
Steve 1 is offline
Old 07-17-2003 | 05:01 PM
KNOT-RIGHT's Avatar
I Have had excellent luck with Arnesons
There proven and durable!!
Just my 2 cents
How ya like these eggbeaters!!
KNOT-RIGHT is offline
