#1 R drive vs Alpha drive >
Old 07-11-2003 | 09:13 AM
Pat McPherson's Avatar
Default #1 R drive vs Alpha drive
Anyone know if a 1980 R drive will bolt up to a 1984 Alpha?
Asking for someone else that blew his drive up.
Anyone in the northeast have a good used alpha drive for a V8?
I think 1.5 ratio...
Thanks,
Patrick
Pat McPherson is offline
Old 07-11-2003 | 04:49 PM
David's Avatar
Yes it will bolt up, but double check the length of the input shaft to make sure it is correct for your application.
David is offline
Old 07-11-2003 | 06:32 PM
cuda's Avatar
Yes
cuda is offline
Old 07-11-2003 | 08:47 PM
Thanks Guys, The MR is going on then.
Patrick
Old 07-12-2003 | 05:48 AM
Biggus's Avatar
It will bolt up but the #1 drive is quite a bit weaker than an Alpha. The lower drive shaft is much thinner than an Alpha.
Biggus is offline
Old 07-12-2003 | 08:28 AM
the yoke on in-line 6 is shorter than a V-8
Dixie Doug is offline
CIG3
09-13-2017 06:48 AM
ACrooks69
Swap Shop
9
01-26-2009 10:25 PM
mountainmadness
Drives and Lower Units
8
11-30-2007 08:33 PM
Daddio
2
01-25-2006 05:09 AM
