How to remove exhaust tips? >
Old 07-15-2003 | 11:03 PM
Krumbsnatcher's Avatar
Question How to remove exhaust tips?
I just had the boys at Stainless Marine custom make me a set of offset tips to correct the exhaust alignment problem I posted earlier.
http://www.offshoreonly.com/forums/s...threadid=53491
Now my problem is removing the old tips. I have removed the hardware cut the silicone around the tips and even pounded on the tips, they will not budge. I was thinking about using an acetylene torch, but do not want to hurt or discolor the gel-coat.
Any suggestions, I know this must be a common problem.
When i say pounded tried to knock them loose and hit them out from the inside.
Stubborn little tips!
Krumbsnatcher is offline
Old 07-15-2003 | 11:23 PM
BIGGER HAMMER!!!!!!!!!!!!!!
You also might try getting a long, thin knife and try to cut the silicone or (hopefully not) 5200 from the inside between the tips and transom hole.
Griff is offline
Old 07-16-2003 | 05:25 AM
Raypanic's Avatar
Use heat, I used a propane torch on the inside of the tip. I had 6 mounted on my fountain with 5200. They pretty much fell right off. I had a puller rigged up to put pressure on the while applying the heat but after the first two I just had a friend pull on them with a pair of vise grips when they got hot. Be carefull you dont breathe in the fumes - NASTY It worked much better than I thought. I took about 5 minutes of even heating just keep the torch moving. This was a tip from a fellow OSO member.
P.S. I had no problem with the Gelcoat.
Ray
Raypanic is offline
Old 07-16-2003 | 05:31 AM
Raypanic's Avatar
Here is a link:
http://www.offshoreonly.com/forums/s...threadid=47440
Ray
Raypanic is offline
Old 07-16-2003 | 06:38 AM
Dork
Had the same problem earlier this spring. Did the same thing you did, trying to beat them out from the inside. They wouldn't budge at all.
A heat gun worked for me to soften up the sealants. I used a 2x4 that i shoved into the tips to get leverage up, down, and side to side to loosen them up. A little more heat and some more pressure with the 2x4, out they came. Good luck.
Old 07-16-2003 | 11:11 AM
Well Heat looks like it is the answer, that should not be a problem since the boat is currently in the garage and it is a record heat week of 128 Degrees in Havasu, Argghhh.
I will try the heat this weekend and let you know the results.
Thanks Raypanic and Dork for the info.
Old 07-16-2003 | 01:28 PM
Raypanic's Avatar
Boy with 128 degrees I bet you could use a bic lighter to finish them off!
Ray
Raypanic is offline
Old 07-16-2003 | 08:22 PM
StrikinLightnin's Avatar
Had mine sent out to get stainless flappers welded
inside the tips.
First took off all mounting.
Cut out all RTV silicone inside and out.
Then got a screwdriver and pride between
the hose and tip.
As I did this I sprayed WD-40 in between
the hose and the tip.
With a rubber strap wrench from Sears you then
can start twisting the tip loose from the hose.
Good Luck!
Dennis
StrikinLightnin is offline
Old 07-16-2003 | 09:46 PM
formula31's Avatar
A thin piece of piano wire worked between the flanges and the transom may help. Like a garott.
formula31 is offline
Old 07-16-2003 | 10:51 PM
Well I have plenty of ideas to try one of them should work.
I will let you all know how it went.
bolgna
4
01-23-2008 06:23 PM
handfulz28
12-24-2006 07:16 AM
jeff32
01-02-2006 08:52 PM
96f350psd
0
01-24-2004 10:21 AM
Raypanic
12
11-12-2002 07:56 AM
