Exhaust Tip Install - Rubber gasket??? >
Old 07-17-2003 | 10:34 AM
Raypanic's Avatar
Default Exhaust Tip Install - Rubber gasket???
Has anyone installed an exhaust tip without gluing it in?
I was thinking of cutting a rubber gasket to sandwich in between the tip and the fiberglass. This way changing or repairing would be easy.
I have seen the flanges for dry pipes made from silicone so I think If I get the right material it should last. I am thinking of putting a collar on the inside to help with the mounting rather than just the washers and nuts too.
I am buying the HPI Transom tips.
Ray
Raypanic is offline
Old 07-17-2003 | 10:49 AM
Krumbsnatcher's Avatar
I have not yet but I believe they are called beauty rings. This is the setup i have being built for my 2" offset problem. Daryl at Stainless Marine recommended it for my custom exhaust tips.
It is a ring that basically slips over your tips from the outside and seals against your tips I would imagine you would then silicone the seal just to be safe.
Anyone else ever use a beauty ring?
Krumbsnatcher is offline
Old 07-17-2003 | 01:48 PM
Kentz
Yes, I just replaced my factory-supplied corsa silensors with straight tips. Corsa used a 1/8" rubber-type gasket. I re-used the gasket with just a "dab" of silicone caulking. For above waterline tips, 5200 is way overkill.
no leaks/drips. Tips just needed a light tap from a mallet.
carter38
08-30-2007 05:01 PM
nordic95
1
07-09-2007 09:19 AM
SSComp
1
10-01-2004 05:32 PM
Bryanw
0
07-25-2004 05:53 PM
Tantrum
04-29-2003 07:46 PM
