Oil bath trailer hubs >
Old 07-18-2003 | 07:53 PM
JnT's Avatar
JnT
Default Oil bath trailer hubs
I think they are marketed as Turbo Lube hubs.Anyone have any experience with them?
JnT is offline
Old 07-19-2003 | 01:46 PM
Rip
The only ones, I know of are http://www.bearingbuddy.com/
I am not sure, if that is what you are lookinf for tho
Old 07-19-2003 | 02:33 PM
JnT's Avatar
JnT
These are what I'm considering. http://www.championtrailers.com/turbo_lube.htm
JnT is offline
Old 07-19-2003 | 02:50 PM
Nevr heard of them, but it seems to me that the oil would be more easily effected by a small amount of water intrusion than grease would.
Griff is offline
Old 07-19-2003 | 03:08 PM
cuda's Avatar
I spoke to one of the Owens brothers of Owen and Sons Trailers. He doesn't like them. He said if they get a crack or somehow lose the oil in them, you are done. Whereas, if it is a grease bearing, even if you lose the buddy bearing, you are running with a greased bearing. You can go quite a way with no buddy bearing.
cuda is offline
Old 07-19-2003 | 03:58 PM
Default Oil filled hubs
I've had to deal with them on a couple of trailers: the concept is nice, but the reality is, that they can, and do occasionally leak their lube out(usually cracked or loose plastic bearing cap). I personally prefer the safety factor of the greased hubs.
Hugh / Offshore Performance
hpoffshore is offline
Old 07-19-2003 | 06:36 PM
Scott B's Avatar
I have used them on many trailers. Give me grease anytime. As stated above, there is no margin for error. A loose or cracked cap, bye bye oil and bearings.
FWIW, I switched all my boat trailers to Amsoil grease after experimenting with it on one of em. Runs cooler than anything I have ever used. just put 4000 70+ mph miles on a brand new boat trailer using it, and the hubs are still tight on the axles shafts..
Scott B
Scott B is offline
Old 07-20-2003 | 01:34 PM
JnT's Avatar
JnT
Thanks very much for the help.I'm definitely going to heed your advice and stick with the grease!Hope the weather cooperates with the rest of all your boating season!
JnT is offline
Poker&Run
3
10-14-2008 11:05 PM
handfulz28
1
07-29-2008 10:58 AM
jmherbert
1
05-16-2007 12:04 AM
Jim Diesel
9
06-26-2006 10:36 AM
Dusty Times
5
06-11-2004 10:50 PM
