Reverse Lock valve >
Reverse Lock valve
Reverse Lock valve
Old 07-20-2003 | 09:54 AM
XCAV8's Avatar
Default Reverse Lock valve
can i eliminate this??? from what i understand its purpose is to keep the drive from kicking up when transmission is in reverse......
i've been told that a newer style trim pump does NOT require a reverse lockout valve... just trying to confirm what i've been told.... any info on how this works will be greatly appreciated.... thx X
XCAV8 is offline
Old 07-20-2003 | 10:29 AM
Mbam's Avatar
Offshoreonly Advertiser
Yes, Oildyne pump does not require reverse lock, just run the 2 hoses from the drive directly to the pump.
Mbam is offline
Old 07-20-2003 | 01:58 PM
XCAV8's Avatar
Thx Mbam, now i just have to verify that the pump i have is the new style Oildyne...??? It has a plastic reservoir with fill cap in the reservoir...??? I think this is the new one ?????/
Thx again X
XCAV8 is offline
Old 07-20-2003 | 02:59 PM
David's Avatar
That pump will work with no reverse lock.
David is offline
Old 07-20-2003 | 03:57 PM
Mbam's Avatar
Yes, that is an Oildyne. You might need adapters to go from the original #3 inverted flare to the #4 that is used on the later pumps.
Mbam is offline
Old 07-20-2003 | 05:22 PM
XCAV8's Avatar
Ok , so do i put the 2 lines that went into the reverse lock together with a coupler????
thx again
XCAV8 is offline
bstasch
Sonic
13
06-17-2008 10:40 AM
Pure Energy
4
06-22-2004 08:47 PM
LPA2106
04-21-2004 04:37 PM
Pure Energy
07-22-2002 11:56 AM
