Paging Prop Experts . . . >
Old 07-21-2003 | 08:49 PM
Elite Marine's Avatar
Default Paging Prop Experts . . .
Now that I'm finally running what I consider the best prop for my boat tested to date, I have a few questions.
I'm running a 28P Bravo 1 on my 24' Pantera with 650HP. Total weight approximately 4600#. I will get better performance numbers as I just received my GPS, but currently I am running about 85 MPH (Speedo) @ 4800 RPM.
1. Does this speed/RPM seem right?
2. What can I do to get my RPM's up without sacrificing low/mid range performance?
3. I'm be interested in Lab finishing prices, please quote finishing my prop and also a new Bravo 1 finished from you shipped to Hillside, IL 60162. (See Jeff, I'm not cheap or poor!!)
Thanks,
Kirk
Elite Marine is offline
Old 07-21-2003 | 10:02 PM
Send all this info to Darin at [email protected]
He's your best bet on this subject
88 MACH 1 is offline
Old 07-21-2003 | 11:32 PM
What gearing in the drive?????
With a 1.5 drive a 28 @ 4800 going 85mph has a 0% slip ratio. With 10% slip which is fairly good for V's, its 77mph.
You would pick up 400 or so rpms by dropping to a 26 Bravo. Labbing the 28 would probably give you 200-300 rpms.
Griff is offline
Old 07-22-2003 | 01:01 AM
HOUSTONPROP's Avatar
Kirk,You have mail/
Darin/ Houston Marine Propeller
HOUSTONPROP is offline
Old 07-22-2003 | 08:39 PM
I must be real efficient with 0% slip huh Griff!!!??
Like I said, I'll get true GPS reading this week to see what I'm really doing.
Darin,
I'll check my email, thanks, I knew you'd have the answer and the right prop!!! I'll get back to you tomorrow!!
Kirk
Old 07-22-2003 | 09:51 PM
Default your mail
BOX is full Kirk,I will try later or my phone is on 24 /7
oh!That doesnt mean I"LL ANSWER No, really 24/7
IT'S THE TIME OF THE YEAR! Darin
Old 07-23-2003 | 09:55 PM
Cleared the box . . . still says full. Something is wrong!
Can you try again??
Thanks,
Kirk
Old 07-25-2003 | 04:55 PM
Angry My GPS Lies
O.K. I have to tell the sad truth. My GPS Lies!!!!!
I am actually running 78 MPH at 4650 RPM with the Bravo 1 28P. I am very disappointed. I called Darrin at Houston Prop and he recommends a 26 increased to a 27 with some cuppping and lab finishing. I'm going to go with his recommendation, but need to purchase my drive first.
What numbers should I anticipate with a 27P at 5000 - 5100 RPM?
Old 07-25-2003 | 05:40 PM
Jonas's Avatar
sell the gps that is what i should do..
sell gps = positive cash flow
every time i use my gps = cubik negative cashflow-
Jonas is offline
Old 07-25-2003 | 06:02 PM
Dumbest thing I've done buying that damn GPS. My speedo was wonderful until that GPS showed up!!!!
Waterboy123
Prop Talk
2
01-28-2007 11:36 PM
KNOT-RIGHT
5
09-29-2004 10:20 AM
Sonny Spectre 30
09-25-2003 07:17 AM
RonS
02-05-2003 01:02 PM
