Air voids
Old 07-22-2003 | 09:50 PM
Whitey's Avatar
Default Air voids
Can anyone tell me how common air voids are in the gel coat? I have a couple and was wondering if this is common or is this a screw up in the manufacturing process? Thanks Dwight
Whitey is offline
Old 07-23-2003 | 07:32 AM
BillR's Avatar
OSO Moderator
Very common.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 07-23-2003 | 07:43 AM
KiloKat's Avatar
KiloKat
It's inherit with the process. Not a problem as long as you repair them when they appear.
Everything Runs Better On Alcohol
www.nautiboats.com
KiloKat is offline
Old 07-23-2003 | 09:31 AM
Audiofn's Avatar
Charter Member #232
All of thee above sounds good to me. It is a inherent problem with the process and it is very common. If the manufacturer did not screw it up you would not have them but all boats do. Make sure you fix them to keep the water out.
Jon
Put your best foot forward!
Audiofn is offline
Old 07-23-2003 | 04:40 PM
Whitey's Avatar
Thanks guys, The manufacturer told me the same I just wanted to make sure I was not just getting a line...Dwight
Whitey is offline
Old 07-23-2003 | 04:54 PM
Raypanic's Avatar
I foound one while waxing my boat for the first time, Saw what looked like a scratch started rubbing harder, pop I fould about a 2" dia x 1/2" deep pocket. It was above the rub rail. I had it fixed no-problem. Kind of a pain shelling out the $$$ to get it fixed though. But it was a used boat.
Ray
Raypanic is offline
Old 07-23-2003 | 06:29 PM
Reindl Powerboats's Avatar
Should not be there if the hull is done correctly, but they are no big deal to fix either.
Reindl Powerboats is offline
mcraymond3
2
05-05-2008 08:00 PM
ShootinTheBreeze
6
06-21-2006 07:38 PM
ScottB
Outerlimits
0
06-29-2005 09:33 PM
derekdeben
09-24-2004 09:18 PM
skatermike24
04-25-2003 11:29 AM
