Part Help - need old style trip pump reservoir with single bolt through bottom >
Old 07-28-2003 | 11:19 AM
Default Part Help - need old style trip pump reservoir with single bolt through bottom
I have an oildyne pump reservoir that is cracked and I need a new one. I have been told that they are no longer available through Mercruiser. This is the same pump that is sold to trim every bravo drive. I need the old style reservoir with a single bolt that holds it on from the bottom. The newer style has four bolts that holds in on from the top. I don't know if my pump has the 4 tabs or not. I will check soon. I just thought that someone has to have a few of these pumps sitting around.
Thanks!
Steve
[email protected]
stevel is offline
Old 07-28-2003 | 02:02 PM
formula31's Avatar
Good Luck. I know it's mickey mouse but I have used Marine Goop to seal those cracks and it works great. Make sure its really clean if you try it.
formula31 is offline
Old 07-28-2003 | 07:14 PM
Thanks Formula31. I may just try that. I don't have marine goop, but I wonder if 3M 5200 will work? It sticks to everything and I don't think oil will affect it.
Merc makes a retrofit kit but it is almost the cost of a new pump!
My pump was made in 1991. The new style bottle fits everything 1992 and later. Figures........
Steve
stevel is offline
Old 07-28-2003 | 09:05 PM
Biggus's Avatar
You can get an aftermarket res from Sierra. Up here we get Sierra parts at out NAPA store
Biggus is offline
Old 07-28-2003 | 09:13 PM
mrv8outboard's Avatar
coolrunning racing
if you buy the upgraded tank it will fit the early pump housings. did all three in my boat last year.
mrv8outboard is offline
Old 07-28-2003 | 09:23 PM
Biggus - thanks, I will see if Sierra makes the old style reservoir.
mrv8outboard - How did you attach them??? My tank and the new tank look the same. However, my tank mounts with a single screw going up the center from the bottom. The new style tank looks the same, but it mounts with 4 screws from the top. My pump is one year too old to have a place for the 4 screws. I don't have the 4 holes on the mounting plate. After 1992, the holes were provided.
Thanks!
Steve
stevel is offline
Old 07-28-2003 | 09:50 PM
Biggus's Avatar
Sierra does make the old single screw res. I repaced one on Friday.
Biggus is offline
Old 07-29-2003 | 07:23 AM
coolrunning racing
my pumps were 1993 vintage thats why. like all have said your local napa store can get the old style.
Old 07-29-2003 | 08:21 AM
Thanks guys. I just ordered 3 new ones. ( I have three pumps, it is probably a matter of time before the other two go)
Thanks!
Steve
stevel is offline
SeaWeasel
2
07-21-2005 04:29 PM
TomR
9
04-29-2005 06:13 AM
tssteph
1
01-14-2004 01:17 PM
guillermof
4
09-13-2003 11:28 AM
