mirage vs bravo 1 vs revolution 4 >
Old 07-28-2003 | 12:09 PM
Default mirage vs bravo 1 vs revolution 4
I need some prop advice. does anybody have a test comparing above props.
I have a crownline 266 ltd with 496 Ho
and mirage plus 21p prop WOT 5000 RPM
+/- 60mph GPS. I want a 4 blade prop witout losing to much on top end?
docricky is offline
Old 07-28-2003 | 08:34 PM
The Rev 4 works best on a Crownline. A 21" Rev 4 should give you about the same top end, but much less slip out of the hole and at cruise, and be a lot smoother.
bobl is offline
Old 07-29-2003 | 09:39 AM
throttleup's Avatar
Other things to consider is the behavior of the boat. How does the bow carry...stern carry? The Mirage is a bow lifting prop...the Bravo I a bow lifting prop ...the Rev 4 is a Full Hull Lifting prop and Hydromotives are stern lifting props. With the 496 HO you should run at WOT 4900-5000RPM. The addition of the 4th Blade can indeed net a speed loss of about 1.5 knots but this is not truee 100% of the time. If you are not experienceing the benefits of a high performance prop then you may never feel the decrease in speed by adding the 4th blade. And of course Blueprinting the prop generally produces 2-4 MPH Increases in speed!
Julie
Throttle Up Propellers
877-842-6855
throttleup is offline
Old 07-29-2003 | 09:57 AM
HOUSTONPROP's Avatar
Default before you buy!
I would try a 19 pitch and a 21p. REVOLUTION FOUR before you buy anything ,you will see and feel the difference. Darin
HOUSTONPROP is offline
Old 07-29-2003 | 01:54 PM
Default Larger Blade area
The Mirage plus has a larger blade than the old style prop so it will lift the bow better!Darin
Old 07-29-2003 | 03:46 PM
Default rev4 vs bravo
Thanks for replies guys
smallest pitch in Bravo 1 is 22 vs mirage plus 21, I would expect to drop from 5000 to 4800 rpm WOT I'm at a elevation of 2000ft, If I take it to the coast will I gain 200 RPM?
If I blueprint/lab finish Bravo 1 22p what will it do to max RPM. Would I need a 22 or 24p?
If the bravo has same bow lift character as mirage plus I would probably try that.
regards
Rick
docricky is offline
Old 07-29-2003 | 06:32 PM
Rick, I would certainly try the 21 pitch Rev4 on your boat. I have set up dozens of Crownlines and that hull "likes" the Rev 4. The Rev 4 will turn almost exactly the same RPM as your Mirage plus 21" (on that hull). Crownlines don't perform well with bravo 1 props until you get some serious HP in them.
Bob
bobl is offline
Old 07-31-2003 | 04:05 PM
Hi Bob
The consensus seems to be Rev 4.
If I'm maxing out on RPM with a 21p mirage plus and get a blueprinted rev 4. Taking into account that I'll be using it on the ocean too (salt water 2000 ft drop in elevation)Do I get a 21 or 23p blueprinted rev 4??
regards
Rick
docricky is offline
Old 08-01-2003 | 07:38 AM
Default TRY THE 21 REV FOUR
I would try the 21 pitch rev four ,These props are very thick and have a large blade area,and sufficient cupping on the pitch and rake lines of the blade. I think a 23 would be too much even at the elevation change./
Darin> Houston PROP 281-580-PROP(7767)
Old 08-03-2003 | 01:04 PM
docricky I have a 21rev 4 like new.tryed to pm you but you do not accept pm? James
FloridianSon is offline
