Need info on 575sci's and xr drives >
Old 07-28-2003 | 08:39 PM
mfb357's Avatar
Default Need info on 575sci's and xr drives
can anyone give me advice or any problems with late 01. 575's. and how do the xr's hold up behind them? thanks MFB
mfb357 is offline
Old 07-28-2003 | 08:43 PM
Von Bongo's Avatar
35 hours on mine behind a 28 Pantera and no problems what so ever.
Von Bongo is offline
Old 07-28-2003 | 10:59 PM
mcollinstn's Avatar
Friend's boat at 11,000 pounds. Superchillers, boost turned up to 7psi, and ECM reprogram.
Eats XR's.
mcollinstn is offline
Old 07-29-2003 | 06:23 AM
Quiet Storm's Avatar
Broke both the XR's in a 386 Sonic. Nothing done to the motors.
Quiet Storm is offline
Old 07-29-2003 | 11:26 AM
75hrs. XR/ITS, Intercooler. ECU reprogram,Fuel system upgrade. Boost 7.5 No problems yet.
zahndok is offline
Old 07-29-2003 | 12:04 PM
I'm curious about the inter-cooler and ECU upgrade. I understand that with minor changes you can boost the hp by 200. Someone said that there is a kit offered.
Anyone have any info on this?
Old 07-29-2003 | 12:12 PM
KAAMA's Avatar
zahndok, what make and length of boat do you have?
KAAMA is offline
Old 07-29-2003 | 02:03 PM
27 Hallett. I opted for the Whipple Intercooler over the Superchiller to save height and keep it under the hatch. It ran rich on the bottom with the top adjusted correctly before the ECU reprogram.
zahndok is offline
Old 07-29-2003 | 07:35 PM
mcollinstn's Avatar
friend has plenty of space under the scoops and went with the big superchiller. Supposedly Dynoed at 720 at 7 pounds with 70 degree water thru the chiller (I have not seen any dyno sheets).
I do know it eats XR's though (I bought his XR's after the last rebuild when he went to Bmaxes).
**yes, he lost a few mph with the Bmaxes and is looking for more motor **
Old 07-29-2003 | 08:42 PM
mfb357's Avatar
thanks guys I don't know much about the 575's as to what the boost should be at. its a stock boat, 47 lightning with triples. 88 hrs. the drives appear fine, oil is clean, no metal. Has anyone had trouble with the fuel line recall or bad alternators? thanks Mark B.
mfb357 is offline
stephen francis
Drives and Lower Units
4
05-07-2008 11:21 PM
f311fr1
8
11-11-2007 07:48 PM
HP-J
12-12-2002 07:26 PM
timucin
07-26-2002 12:53 PM
Dock Holiday
1
01-12-2002 03:25 PM
