502 timing
Old 07-29-2003 | 07:28 PM
victory32
Default 502 timing
When setting up timing (after the static is set) to set the 8 degrees base I jumped the a-b terminal and the motor dies, the tool from merc is just a jumper from a-b, whats the deal?
Old 07-29-2003 | 08:36 PM
Dennis Moore
You must have an older 502 EFI. You need to set the idle speed to about 2000 rpm and then jump the wires. The newer EFI's don't need the rpm increased.
Dennis Moore
Old 08-02-2003 | 11:04 AM
victory32
1998 mpi motors, does this qualify for the 2000 rpm timing set up ???
redscarab
7
09-19-2007 12:12 AM
BajaBennett
3
06-13-2004 06:43 AM
kennyo
3
05-10-2004 03:58 PM
Helmwurst
3
03-04-2003 12:10 AM
Helmwurst
6
05-22-2002 09:38 PM
