Alpha Help
Old 08-01-2003 | 09:59 AM
racer-x6's Avatar
Question Alpha Help
I HAVE A ALPHA 1 GEN 2 UNIT THAT IS KICKING MY #$^@^. WHEN THE UNIT IS TRIMED DOWN FULL AND TURNED RIGHT OR LEFT FULL IT MAKES A NOISE THAT SOUNDS LIKE A GIMBLE BEARING. THIS IS WHAT I HAVE DONE .
1. REPLACED THE BEARING TWICE. BOTH INSTALLED USING ALL PROPER TOOLS AND ALIGNED.
2.CHECKED YOKE SHAFT AND U-JOINTS FOR SLACK, FOUND NONE.
3. CHECKED THE UPPER DRIVE BEARING FOR SLACK, FOUND NONE.
IF THE UNIT IS TRIMED UP OR TURNED JUST A HAIR IT WILL STOP. IT HAS BEEN IN ANOTHER SHOP FOR THE SAME PROBLUM AND THEY COULDN'T FIX. HELP!!
racer-x6 is offline
Old 08-01-2003 | 10:22 AM
I had 1 that someone put a coupler in that has those rubber dampers between the coupler & flywheel had 2 missing.It made the same noise.Pull the drive off ,look at the coupler-splines through the G/bearing ,crank the engine and see if it rotates and stays in line.
Dixie Doug is offline
littledcsrodshop
Wanted
5
07-24-2008 12:03 PM
srracer
2
04-20-2006 03:49 PM
ch18346
Fountain
1
08-15-2004 08:42 PM
