Fuel Regulator Return line project Update! >
Old 08-11-2003 | 11:35 AM
Krumbsnatcher's Avatar
Default Fuel Regulator Return line project Update!
Previous thread
http://www.offshoreonly.com/forums/s...threadid=56091
Ok guys even in 115 Degree heat I managed to pull off one more project on this boat. I have read alot of posts about fuel regulators and talked to some very knowlegdgabel people including Aeromotive who made my fuel pump and regulator.
Anyway I decided to give you an update and help others out there tackle this job.
Here is a picture of where the return line on the regulator.
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-013.jpg
Krumbsnatcher is offline
Old 08-11-2003 | 11:37 AM
Now you need to locate your fuel fill at the tank.
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-015.jpg
Old 08-11-2003 | 11:38 AM
Now that you have the hose off plug the fuel fill with a rag so not to cause a fire hazard. I know this is trivial but important.
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-016.jpg
Old 08-11-2003 | 11:40 AM
Now that you have the hose off cut out a 3" section.
This line is very heavy duty and has steel wire embeded in it so when you cut you will need a cutting wheel. I used a chop saw with a basic cutting wheel attached. Gets a little smoky from the burning rubber
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-017.jpg
Old 08-11-2003 | 11:42 AM
Now you can either buy the EFI fuel return line kit from Moroso, which is what I did or CP Performance sells just the return fitting alone.
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-019.jpg
Old 08-11-2003 | 11:45 AM
The return line has a 90 degree bend it is important that you point this toward the tank. I know this is trivial but at least I covered it.
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-020.jpg
Now hose assembly
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-021.jpg
Old 08-11-2003 | 11:46 AM
Now reinstall into the boat
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-022.jpg
Old 08-11-2003 | 11:49 AM
Attach your return line I used 12 ft of 3/8" return line.
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-023.jpg
Old 08-11-2003 | 11:50 AM
Last I attached the return line to the regulator using an Earls -6 pushon fitting and the job is done.
I hope this helps somone out, I know I struggled with this issue on a previous thread.
Attached Thumbnails Fuel Regulator Return line project Update!-fuelline-024.jpg
