jetting question
What kind of actual performance gains can be had from propper jetting? The plug colour I have know is a dark chocklate brown, would I gain as much as 200 - 300 more rpm by jetting a bit leaner or is the risk of dammage not worth the extra speed? (Dumb question)
If jetting is too rich & you leaned to correct A/F ratio you could gain 200+ rpms. If jetting is too lean, you may gain 200+ for a short time before the motor melts down. Key point is correct jetting from being too rich. I remember where Hot Boat had a motor on a dyno & motor gained 85 hp in getting jetting right on.
34Mach1
03-26-2008 01:50 AM
