anyone put stellings boxes on 93 35 fountain >
Old 08-13-2003 | 12:25 PM
Jonas's Avatar
Default anyone put stellings boxes on 93 35 fountain
have purchase in motion for a set of stellings stand off boxes any input
93 non step fountain 35
540 hp motors runs 82 +/- depending on the conditions now fairly easily, std braco 1's with nose cones.
Jonas is offline
Old 08-13-2003 | 01:28 PM
You should go with the IMCO boxes...you will need to change your hyd. steering.
They have wing plate mounts for the new rams.
If you do the neutral setback ones, you will have to do shorter lowers.
The motors will have to come out to install the boxes.
Back4More is offline
Old 08-13-2003 | 01:30 PM
Attached Thumbnails anyone put stellings boxes on 93 35 fountain-mvc-048s.jpg
Old 08-13-2003 | 01:35 PM
Jonas's Avatar
i was told these boxes are (race boxes adjustable x )?
and i would not be able to mount my steering huh...
hmmm not good.
i gotta call him again,,
thanks
Jonas is offline
Old 08-13-2003 | 01:40 PM
The only way you could move your X is shorter lowers or move the engine CL up...as in remount your engines higher in the boat.
Old 08-13-2003 | 01:42 PM
Jonas's Avatar
oh that would be no fun!
Jonas is offline
Old 08-13-2003 | 01:49 PM
If you have Latham steering they make a kit to use their steering with Stellings boxes
Dixie Doug is offline
Old 08-13-2003 | 03:02 PM
Jonas's Avatar
i have mayfair
Jonas is offline
Old 08-13-2003 | 03:19 PM
Tinkerer's Avatar
Are they Stelling boxes - If they are then they are probably 3 inch rise but you can adjust them by the bolt holes that you use to mount them to the transom. You don't have to raise your engine with stelling boxes but it helps. With the IMCO boxes you have to raise the engine. If you aren't going to buy the boxes PM me with the info as I might be interested.
Tinkerer is offline
Old 08-13-2003 | 03:32 PM
Jonas's Avatar
I already bought em.
thanks for info
do u know what i do about steering ?
thanks for helpe here guys!
Jonas is offline
