anyone put stellings boxes on 93 35 fountain
Jonas,
I have a 91' 29 Fever that I added extention boxes
to. The boat didn't have hydraulic steering at the time,
but when I put the boxes on I routed the hydraulic lines
through the ext boxes. I went with the stellings boxes
and raised my X dimension 2 1/4 inches. I also raised
my engines 1 inch, but you can get away with leaving
the engine height the same with the stellings. I just
raised the engines to have a little more room under
them to do maintenance. If you have big power or
are planning to add big power then Imco has a new
4 X 4 extension box outdrive system that would be
nice....but I'm sure it is pricey. Mayfair might have a kit
or be able to give you some suggestions.
Not sure if Mayfair or Stellings sells it. It was on the boat when i bought it. I would call them to find out. If not, it looks like the kind of thing you could have fabricated for 500 bucks. If you have a problem locating it, I,ll send a picture with some dimensions. Your dimensions may vary.
