Starter bolts are bent
Once and a while my starter would grind when I tried starting my boat. So I took off the starter and found both bolts were slightly bent. I am assuming the bolts must have come loose and the torque bent them. I know the previous owner had a starter bolt broke on the other motor and had to pull the engine to fix it.
Should I put lock tight on the new bolts, I have never heard of starter bolts coming loose.
David
My motors were built in '98 by Innovation and they said they stopped using a support bracket in '94 when they started using the smaller style starter.
Thanks for the reply, it makes sense to put a support bracket on it and I am sure I could find one easy enough.
